reproduce the issue
If you consumed some of the threads on this forum regarding SadFace, you will have noticed the constant suggestion of debug logs
An over simplified explanation is that when ever you get a SadFace your system has experienced one of âthousandsâ possible reasons for the Kodi-process to be prematurely / unexpectedly terminated. There might be a gazillion reasons so to make a more nuanced fault-display, but since there is regular updates of the code, which often change behavior of core, add-ons and even OS. That makes a maintaining a more detailed fault-display a âhigh chance of wasting of timeâ. OSMC has a small dev. -team, but active and helpful user base. This makes it preferable to diagnose issues in forum, a lesser load on devs. and âyour issueâ could be solved publicly and another user can enjoy the âsolveâ.
So to get help regarding your issue, follow @ActionA suggestion
Thatâs right, there are lots of reasons this could occur and as such there are lots of ways to fix it, we just need to work out which way is needed for you hence the request for logs.
Basically Kodi is crashing and restarting, itâs as simple as that, thatâs what triggers this.
It is exactly like that. Do you feel better now? Since youâve been on the forum for years, you should know that people here are VERY helpful and need the debug logs to do so.
Opening a thread just to blow off steam is certainly not going to increase the motivation of people who want to help you. Thanks for your interest.
Anyway, I am interested in finding out the triggers for the Sad Face as it might help me diagnose my issue. All the treads I looked at are not helpful for my specific problem. They nearly all depend on having an active network interface which I donât so SSH is not an option and obviously the OS UI is not up and running yet.
I dual boot Windows/Linux so should be able to mount the SD card to âfiddle with filesâ if it helps.
However, my main question is why the lack of documentation for something that seems to be somewhat common?
Alternately, how about making the screen more informative? As it looks likely that there are multiple triggers it would be nice to have on screen a more informative error message. Future feature?
There isnât anything to document: the sad face just means that the operating system is running but that the Kodi application has crashed. There are a great many possible (unrelated) reasons why that might happen - including, for example, an error in a Kodi add-on.
The way you figure out what has happened is by uploading logs, preferably with debugging enabled.
To get as far as a sad face the operating system must be running. If the device has network access then an obvious way forward would be to connect to it via SSH and execute
grab-logs -A
That will upload the logs to the internet and return a URL; posting the URL here will then allow the OSMC guys to get an idea of whatâs going on.
If the device doesnât have network access, then what were you planning on doing with it, exactly, and how were you planning to install updates once they become available? The device needs to be able to access the internet to be able to function properly in the long term.
Ok, just guessing since there is still a lack of information. The first step to negate your "Pi"s boot problem is to rename/move .kodi folder in osmc home folder. Try to restart on the SD card now. If that helps, you could try to read the kodi.log in /home/osmc/[your moved/renamed .kodi-folder]/temp/kodi.log and kodi.old.log for the log from the boot before.
In laymanâs terms⌠the Sad face is the equivalent of sayingâŚ
âSorry your vehicle stopped runningâ
There are HUGE number of reasons that happens.
Try do a web search for âvehicle wonât runâ
You get a huge number of possible solutions, most of which wonât work for the fault a specific vehicle has.
The trick is narrowing down the exact problem, out of the huge number is possibilities, and then finding a solution. That is done by having a skilled person methodically diagnose it.
In this case (software and hardware) the people in this forum are very helpful if you help them by giving them the exact info they ask for.
Is it safe to assume that if someone is asked to provide logs and fails to do so the person doesnât want to be helped by the most helpful community on this planet?
