Hi I had yesterday and today about 20 min. Stream time. That my Vero 4k is simply pronounced. The sad face came. And dix box is re-starved. I have nix s.den settings changed.Noch any new addons installed. Would be really nice if one could fix that. Thanks in advance
You must provide logs so we can see what you want fixed.
I don’t understand the question.
Try writing it in your own language and maybe someone can translate.
I hope I have now done right with the log upload
The url: https: //pasteosmc.tv/axusawotub
I hope you can do something with it.
My problem is that the box just look at restarting by itself
You have some unofficial repos and add-ons, try removing them or starting fresh with mv ~/.kodi ~/.kodi-backup. If that resolves things then it suggests that it may be an add-on causing the issue.
all clear it will try. thank you for the help
You are welcome. Let me know how you get on.
