Hi, tonight, when I turn on the Raspberry Pi 2, there was Sad Face.
I try to reboot, but after the OSMC start schermate, the sad face return.
I send you the results of
paste-log /var/log/apt/history.log
http://paste.osmc.io/licerolixe
and
paste-log /var/log/apt/term.log
http://paste.osmc.io/obujabiwed
thank you
the Kodi log would be much more beneficial since it seems that Kodi is crashing in this instance…
I don’t know what to do: i try to reboot several times, but each time kodi crash on the first schermate.
Does someone know if it’s possible to fix the problem?
Otherwise I will format this evening, but I’ll lose lot of installations.
I have restored a new image of osmc, and today, after only 12 days, I have done the update from command line, using apt-get dist-upgrade, and at the reboot:
SAD FACE!!!
I don’t know why, but after the second update my osmc has always problems!
Here the logs: http://paste.osmc.io/opacinawim
