Good morning,
Today I got a sad face on kodi on a raspberry 3B+, same behaviour after reboot, I have ssh access.
These are the collected logs:
https://paste.osmc.tv/sehugojiti
Can you please point me on the right direction?
Thanks in advance
Good morning,
Thanks in advance
What is your setup?
Why have you commented this out #dtoverlay=vc4-kms-v3d,cma-512 in config.txt?
Good question, I don’t know. Do I need to uncomment?
About the setup do you mean the hardware or the configuration files?
[pi4]
dtoverlay=rpivid-v4l2
arm_64bit=1
kernel=kernel.img
[all]
disable_overscan=1
start_x=1
disable_splash=1
disable_fw_kms_setup=1
include config-user.txt
Yes, that line is needed.
I meant is it headless or any other reason that made you editing the config.txt file
I uncommented and it works. You are a magician, an artist
Thanks a lot
