Using OSMC (17.8-084) on a Raspberry Pi 3.
So since some days i get the sad smiley face after every “reboot” command trough SSH or if I use the Restart Button in the GUI.
Only if i type shutdown -r now it works again, sometimes even that doesnt work and I need to retype shutdown -r now.
Dont rly now why - also tried to rename the .kodi folder to .kodibackup but didnt helped.
Just wanted to point out that the problem occurs everytime if i type “reboot” but not shutdown -r now.
Since yesterday even shutdown -r now doesnt work @bmillham
@fzinken
Iam pretty sure that i enabled the debugging. BEFORE i couldnt even get the gui working with shutdown -r now
Here is one more log: https://paste.osmc.tv/ajinumuneb.vhdl
If that is also not right, then i cant help you because i cant get in the GUI to enable the setting.(Sad smiley)
I have also a problem with: grab-logs -A
This error comes:
#Edit: grab-logs -A works now, after the reinstall of libpython2.7-minimal and libpython2.7-stdlib https://paste.osmc.tv/aluyegequw
That very much points to a broken SD card as @sam_nazarko indicated.
If you want to check it write some files to it power down than start and check if the files are still there
Complete Shutdown and then replug the power supply? Or just a simple reboot or shutdown -r now?
Because the new file that i created under /home/osmc/Test/Test.sh is still there after a reboot.
Alright, will do it after the libary scann is completed (Sad Face disappeared after i changed 2 times the kodi folder and had it off for some hours).
I had also the x11 Launcher installed before i renamed the kodi folder:
Could that be also a problem? Because right now i didnt installed the launcher/addon (dont know how to name it correctly) and had 2 successful reboots.
