I experience a sad smiley boot loop for a couple of days now. I have no clue what might have caused an error. The last thing I installed was the FirefoxSyncServer, but OSMC was running for days flawlessly (as far as I can tell).
With OSMC I installed: nginx, mysql, php5-fpm, firefoxSyncServer 1.5 (newest) and after receiving the smiley, I did update/dist-upgrade.
I guess the line (jounralctl): "Oct 14 08:56:16 osmc mediacenter[889]: Kodi exited with return code 139 after 0 hours, 0 minutes and 2 seconds"
gives the reason, why kodi is crashing. But I am no professional and I have no clue what to do now.
Does anyone have hint, what to look for and what to try for my installation?
the kodi web server port was changed to 8080, if I remember correctly. Right now I can not remember if I disabled the kodi web server, but somehow I was forced to change the port to make my yatse work parallel to nginx.
And the nginx listens on port 80, [::]:80, 443 and [::]:443
that configuration worked for me for weeks with automated reboots every night.
Exit code 139 means that Kodi crashed with a segmentation fault - which unfortunately is just a very generic type of crash caused by an invalid memory access, typically by trying to dereference a null pointer. In other words a bug in Kodi.
Other than that there are no clues in your log what the cause might be, especially when kodi does not have debugging enabled. I would start by stopping any services like nginx that might be running a webserver to see if Kodi launches - if it does go into Kodi’s settings and change the port or disable the webserver.
If that doesn’t help you could try doing a forced reinstall of Kodi - in theory it should not be necessary but maybe you have suffered some file system corruption. For a Pi 2 it would be:
Then reboot. If that doesn’t help, try renaming your .kodi directory so a new one is created - if this helps then something is probably corrupt in your .kodi folder, whether it be one of the databases, configuration files etc, in which case you would need to find it through a process of trial and error. It is also possible to enable debug mode using advancedsettings.xml to gather more information in the Kodi log:
Thank you very much for your detailed answer, DBMandrake!
I will give your hints a try later on, when I have time to. I will give a report on how the different steps worked out.
That ownerships must have been changed somehow… I can not imagine how, but your tip with chown of the devices did the trick! I did not check the ownership before prompting the chown, so I can not tell if chown or chmod did the trick (or both) but the sad smiley has gone.
Great! Thank you!
I guess I should do a fast backup now
Even if you do have to re-install it would be nice to post mortem why and find out if it is a bug with OSMC or whether it is just a result of disk / filesystem corruption.
If I manually kill Kodi and then restart it, this comes up:
sudo mediacenter
Starting Kodi…
Can’t open device file: /dev/vcio (-1)
Try creating a device file with: sudo mknod /dev/vcio c 100 0
unknown
failed to open vchiq instance
*** Error in `/usr/lib/kodi/kodi.bin’: free(): invalid pointer: 0x031a5cfc ***
Kodi exited with return code 134 after 0 hours, 0 minutes and 1 seconds
