Since some time, when I launch my raspberry PI 3, OSMC don’t boot and display me a sad smiley in a loop. I tried to resolve the problem with command line (in SSH) : sudo apt-get update and sudo apt-get dist-upgrade but the sad smiley is still there.
I’m just beginner, I need explanations to repare it.
You haven’t mentioned you have already tried to move the folder, the command you listed above is not what we are talking about.
As per the FAQ:
Q: I’ve installed the update and now I only have a black screen or a sad face loop, how do I fix this?
A: It’s possible that your Kodi userdata is causing an issue with the new version. The first recommendation would be to move it away and allow Kodi to generate a new userdata directory. This can be done by executing the following commands after accessing the command line58:
OK, have you a link with a description step by step to do a back up and reinstall clean ?
And thank you, I was afraid that I must reinstall… If i do that, all the configurations I’ve done will be erase (I had install Samba, transmission, FTP server, etc ) ?
Sorry no step by step description.
You will have to backup at least the directories /etc/ and /home/osmc/
You could either do that via winscp or on OSMC via a NAS
I had a similar problem after installing the initial Krypton update.
In my case it seemed to be resolved by unplugging the USB cable which was connecting a Dualshock 3 controller to the Pi3.
Once removed the Pi3 booted normally.
I had only 2 external usb HDD. I had unplug and unmount them and nothing change. I have a screen conect with HDMI and a microUSB power supply too. Linux is still running beacause my murmur server (VOIP) and the FTP server works. I think I will reinstall OSMC.
