I’m not new to OSMC, Linux or Windows. That said, I’m sure there’s a lot I can learn.
I installed SaMBa on my OSMC by going into the Apps Add-Ons, selecting SaMBa and installing it. No problem there. I SSHed into the box and modified the smb.conf file (I know, not the right procedure and I should be using the local file). Regardless… the only thing I changed was the shares mount point to /media/VideoVol1 (my USB mounted video drive). I set the owner and group (chown osmc /media/VideoVol1, same for chgrp). I changed the mods to 777. It’s on my home network and wide open is fine with me.
The default, in SMB.CONF is security=user, for the share it’s browsable=yes and read only=no, valid user=osmc
I’ll attache the smb.conf below but it’s the default except for redirecting the included osmc share.
I have an ubuntu machine handling downloads. On that box I issue “sudo mount //192.168.1.162/osmc /mnt/OSMC -o username=osmc”. This works and I can browse the directory. However, when I try to write to it, I get permission denied.
Any ideas why? How can I troubleshoot this? Any suggestions on how to fix it?
Thanks in advance.
Here is an example of the output of an ls -al of the movies:
-rw-rw-rw- 1 osmc osmc 1274291456 Sep 5 15:07 Despicable Me 3 (2017) [HDRip.XviD.AC3-EVO].avi
Here is the smb.conf file:
osmc@OSMC-8:/media/VideoVol1$ cat /etc/samba/smb.conf
[global]
# If you require a fully custom smb.conf create smb-local.conf instead of editing smb.conf so your
# configuration will not be overwritten by samba upgrades. You can use smb.conf as a template by
# copying it to smb-local.conf then removing the config file line below in the new file. If you only
# need to add some additional shares see smb-shares.conf below for a simpler way to do this.
config file = /etc/samba/smb-local.conf
workgroup = WORKGROUP
security=user
follow symlinks = yes
wide links = no
unix extensions = no
lock directory = /var/cache/samba
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
log level = 1
map to guest = bad user
# usershare template share = automount template
# Automount template disabled to work around a samba bug causing crashes accessing external drives.
read raw = Yes
write raw = Yes
strict locking = no
min receivefile size = 16384
use sendfile = true
aio read size = 2048
aio write size = 2048
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /media/VideoVol1
comment = OSMC Home Directory
[automount template]
browseable = yes
-valid = no
valid users = osmc
path = %P
hide files = /$RECYCLE.BIN/System Volume Information/desktop.ini/thumbs.db/
# Add custom shares in smb-shares.conf instead of editing smb.conf so they will not be
# overwritten by samba updates. You can only add new shares to smb-shares.conf, not change
# the default shares or global options. If you need full control see smb-local.conf above.
include = /etc/samba/smb-shares.conf
