Samsung Remote samsung remote nrz
Hi Guy
I have a vero and happy with it. I ‘d like that my tv remote samsung nrz works with it using CEC.
At the moment it is not working at all even if cec is enabled on the tv and on osmc.
Do I have to disable the standard osmc remote ? How I do that ?
ON my TV we can configure the remote to work with home cinema playstation, I tried some but nothing works
I’ve also unplug both tv and osmc …
At the same time I notice as well that when waching a movie and stop doing it, when the screen come back on the osmc gui it keeps the resolution of the movie.
Any idea as well ?
I can create some log but do I have to reboot osmc for the cec connection ?
Did you unplugged TV and OSMC from power for several minutes?
Did you try a different HDMI cable?
Just reboot twice to reduce the size of the logs and then upload logs and share here the URL
The OSMC remotes operate completely independent of CEC or other types of remotes so there would be no reason or benefit to disable the internal receiver.
It sounds like you may have set your refresh rate switching setting to “on start”. The setting is in settings>player>video> and you would want to set it to “always” or “on start/stop”.
In addition to trying a different HDMI cable as fzinken suggested, you could also try switching CEC off and then on on your display and double check in Kodi your CEC settings at settings>system>input>peripherals> and make sure it is still enabled there.
Here is the url :https://paste.osmc.tv/evihayumaj
Thank you
I just checked its on start/stop
I will try your second trick
Even using
I still have the same problem. Any more idea ?
Nobody have an idea for me ?
Can you please clarify the exact issue?
The OSMC remote won’t interfere with CEC.
Try power everything off at the mains for 5 minutes; then boot. If issues persist please upload some logs.
Hello
Here is some logs:
https://paste.osmc.tv/qacoxubiho
I only want that my samsung remote works for basic stuff .
Please some help, my logs will be no more available ….
My remote is not working at all with CEC, I changed my hdmi cable, turn off everything for hour.
It does not change !
