Samsung TV stopped conneting to OSMC - SOLVED
I have RSBRY PI
very old… I installed it 7 years ago and havent updated it since
(VERSION_ID=“2018.04-1”)
all worked fine !!
i use OSMC and mini-dlna and the TV sees the HD and stream video
I now replaced my tv. bought Samsung QE series
for several days, all worked the same. I saw the OSMC as device connected to the TV and streamed video from it.
I rebooted the KODI
and now, the TV don’t see the OSMC as a device to connect
is the problem with the RSPRY or the TV
I rebooted the TV, the KODI and the router…
Porblem solved
remove the power line from the TV for 10 minutes
clears the cache
Glad to hear this.
The CEC implementation has changed since 2018.
It’s not unexpected that such a reset of your devices was needed.
Do let us know if you have any further issues and try and keep your system up to date if possible.
The RSPRY is connected to the LAN and also directly to the TV on HDMI
The HDMY always worked. I could see the OSMC menu when selecting HDMI 1 input
but the LAN option was stuck. The TV didn’t see the files on the HD.
Do you think that the CEC thru the HDMI made some conflict in the TV regarding input sources?
I tried updating it two years ago but had trouble with fonts and other installations so I kept the old version.
If it works - don’t touch. !
It is hard to speculate.
Would need some more info. I wonder if you are relying on an old version of SMB.
