I have a Pi 3b with 3 DVBSky Satellite tuners with TVHeadend and I find that after a couple of days they gradually all stop working and the recordings fail
Has anyone else had this problem and if not what is the best way to try and see what is going wrong
It has just happened. It is currently recording a programme and I wanted to watch something live but it said there are no free adapters when there should be 2 of them. The logs are here
Aug 25 22:45:17 osmc-server tvheadend[884]: subscription: 0351: No input source available for subscription “192.168.1.16 [ osmc | Kodi Media Center ]” to channel “5Spike”
not sure if that’s the issue.
Does systemctl restart tvheadend resolve the issue?
Yes. This is what I get when I try and watch something and there are no tuners but I think this is the symptom rather than the cause. What is causing the tuners to become unavailable
I usually just reboot the Pi to fix it
I can try restarting just TVHeadend next time
It happened again today and I tried systemctl restart tvheadend but this did not fix it. It took a reboot of the Pi before the tuners started working again
Not sure then unfortunately. I don’t have these tuners at hand to reproduce. We will update the kernel version soon for Pi, and this may yield some fixes.
Add the following line: deb http://apt.osmc.tv stretch-devel main
I have made the changes that you suggested and so far it is looking good. all last week the tuners would fail within minutes of a reboot and after the change they are all up and running after a couple of hours
I have some recordings scheduled for tonight so I’ll see how they go
Thank you so much for researching it and giving me the instructions for a possible fix. Your work is really appreciated
All the programmes were safely recorded last night with all three running at the same time. The tuners have been rock solid since the fix was loaded and the Pi rebooted.
Thank you so much for fixing this. I am very happy
