What is the proper way for saving iptables rules?
I know that I can use iptables-save/iptables-restore, but where to put iptables-restore?
Should I put it in /etc/rc.local or should I use iptables-persistent package?
What is the preferred way?
I know how to do it, I am just asking for the proper way.
If you knew how to do it then why ask ? there is a working way and there is failure
since the distro uses iptables per default its not gonna break if you add the persistent package
So, you are suggesting iptables save/restore in Rd . local?
Ideally you want want restore as a ifup.d rule but ConnMan does not support this at this time
sudo -s
iptables-save > /etc/firewall.conf
echo â#!/bin/shâ > /etc/network/if-up.d/iptables
echo âiptables-restore < /etc/firewall.confâ >> /etc/network/if-up.d/iptables
chmod +x /etc/network/if-up.d/iptables
echo â#!/bin/shâ > /etc/network/if-down.d/iptables
echo âiptables-save > /etc/firewall.confâ >> /etc/network/if-down.d/iptables
chmod +x /etc/network/if-down.d/iptables
is working for me
if you what to save your iptables rules after an change to iptables just run below⌠but it will run the same command on reboot or shutdown.
install iptables-persistent, that will take care of all loading at boot time.
If your want to save manually you do a ânetfilter-persistent saveâ. Why debian changed it to netfilter is beyond me.
You will get 2 files in /etc/iptables. rules.v4 and rules.v6. They are plain textfiles and are iptables commands which you can modify and load with ânetfilter-persistent reloadâ
I will try it. Thanks.
If you are using CentOS 6 or Red Hat, you can save it like this:
$ iptables-save > /etc/sysconfig/iptables
Or if you are using CentOS 7, you can save it like this:
$ service iptables save
But if you are using Debian based distro, you can use iptables-persistent to save rules.
$ netfilter-persistent save
All these commands for iptables from here https://likegeeks.com/linux-iptables-firewall-examples/
Thank you.
