It’s impossible for me to scrape my music library… it’s very easy with the movies or tv shows but i can’t do it with my music files… any ideas what i’ve do wrong ?
thx
thx
My problem is the information of the mp3 files i think… i can manualy with a ftp program put the images in each folders… you have to name every images folder.jpg… this take alot time but at the end the result is very great
Did you set or test other scrapers in Settings>Media>Music>Default providers?
yes and it doesn’t work.
Ok, that is your problems. As the scraper would not be able to get the fingerprint right. So you must tag those MP3 before you bring them in the library.
