Hi there
When importing videos osmc is not fetching the movie posters I have to go into the movie and then press refresh in order for it to scrape the info from the web how do I force osmc to do this without going into each file
Hi there
Make sure that the source you added containing the files has the correct scraper selected. Otherwise, provide logs.
It does tmdb
A little dated but most of it still works and/or is true:
Also see:
https://kodi.wiki/view/Updating_or_removing_videos#Update_Library-_Automatic
Here is a link to a log file
https://drive.google.com/open?id=1IsYsMkQAknPahICnUbLWrYDFAwXDKXLSK1NubF3otvI
Please upload logs via My OSMC.
i have solved it
Might help if you tell how so others with the issue could benefit
Please prevent further occurrences of Wisdom of the Ancients and tell us how you solved it.
My movie already had nfo files so i just deleted them
