Got another small problem here
I want my Tv to do up scaling so I set Vero to 1920 x 1080
That give me 1920 x 1080 from HD files and 3840 x 2160 from UHD files (just what I want)
Problem is when Vero 4k is set 1920 x 1080 the Kodi GUI is overscanned on the Tv
Video files play fine with no overscan though file info is over scanned
Any ideas guys (and girls)
Try ‘Just Scan’ or ‘1.1’ pixel mapping on your TV
I have got my Tv set as just scan
Even if I try 4:3 the text from file info is cut off
If I set Kodi to 3840 × 2160 all is well but then Kodi upscales 1920 x 1080 files to 3840 × 2160 and I want the Tv to do the upscale
This sounds strange and I think you actually refer to something else than the “normal” overscan issue people have. Put TV to just scan and then post a picture of your problem.
As you were… My bad
I had just scan on auto should be on
Problem now solved
