Screen to big
I have PI 2B
Screen is much too big on the TV.
How to get it smaller?
settings > system > video output > screen calibration
Can you post the output of ā€˜tvservice -s’ and give a little bit of background (how is your TV connected; which TV is it; do you have ā€˜Just Scan’ / 1.1 pixel mapping enabled)
Best
Hi guys, it was the setting of the TV itself on the second HDMI.
Solved.
Thx a lot.
I always had the same issue even on regular kodi as well, usually -4% zoom fixes the issue (under settings / appearance switch to expert mode and you will see). This is a quicker and better way than screen calibration IMO.
Best way is to disable overscan on the TV. It may be called ā€œjust scanā€, ā€œscreen fitā€, ā€œHD sizeā€, ā€œfull pixelā€,
ā€œunscaledā€, ā€œdot by dotā€, ā€œnativeā€ or ā€œ1:1ā€).
Any other solution involves resizing the video/gui an extra time and so reduces image quality.
