It seems the screensaver is not working after resuming from Standby.
Here is how I tested:
- power up the Vero 4K+
- check screensaver status via json, which returns ‘false’ as expected
- wait until the screensaver starts
- check screensaver status via json, which returns ‘true’ as expected
- press a button on the remote so the screensaver stops
- using the Power menu set the Vero to Suspend
- wake-up/resume OSMC by pressing a button on the remote
- check screensaver status via json, which returns ‘true’ which is NOT expected
- wait longer than the screensaver timeout
- the screensaver does NOT start
After I use the Preview screensaver function in the Settings menu, the screensaver starts working as expected again.
Is anybody experiencing the same?
Thx.
Thanks. I’ll look in to this.
Hi Sam,
Thx.
FYI: I cannot say when this problem got introduced as I only used started using the Suspend option on a daily basis about 5 days ago.
Regards, Carlos.
Just to let you know I’m experiencing the same issue with my Vero 4K+.
Also screen dimming when playback is paused is not working either after resuming from suspend.
Thanks for checking this!
This will be fixed in the next update (for v17).
Gave this a thorough test today and it should be resolved in today’s update.
@Carlosmc1: thanks for the JSON tip; I found that made it much easier to find out when things were (and weren’t) working correctly.
Hi Sam,
I installed the update and tested the Standby function, and can confirm this no longer breaks the screensaver.
Many thx!
Regards, Carlo.
I can confirm. Screensaver working as expected now.
Thank!
