Pulling Screenshots on the Vero4K+:
Screenshot from a 4K movie:
Screenshot from a 1080P Movie:
anyone else having this issue?
Hopefully the issue is now addressed
/etc/apt/sources.list
Thats a Negative sir.
osmc@osmc:~$ sudo apt-get update && sudo apt-get dist-upgrade
Get:1 http://security.debian.org stretch/updates InRelease [94.3 kB]
Ign:2 http://ftp.debian.org/debian stretch InRelease
Get:4 http://ftp.debian.org/debian stretch-updates InRelease [91.0 kB]
Hit:3 http://ftp.fau.de/osmc/osmc/apt stretch InRelease
Hit:6 http://ftp.debian.org/debian stretch Release
Get:5 http://ftp.fau.de/osmc/osmc/apt stretch-devel InRelease [4,712 B]
Get:8 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main arm64 Packages [12.0 kB]
Get:9 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main armhf Packages [25.2 kB]
Fetched 227 kB in 2s (82.5 kB/s)
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
vero3-bootloader-osmc vero364-image-3.14.29-157-osmc:arm64
armv7-eventlircd-osmc mediacenter-skin-osmc vero3-device-osmc
vero3-mediacenter-osmc vero364-kernel-osmc:arm64
5 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 137 MB of archives.
After this operation, 247 MB of additional disk space will be used.
Get:1 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main armhf vero3-bootloader-osmc armhf 1.3.0-1 [1,602 kB]
Get:2 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main arm64 vero364-image-3.14.29-157-osmc arm64 157 [33.2 MB]
Get:3 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main arm64 vero364-kernel-osmc arm64 3.9.157 [964 B]
Get:4 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main armhf mediacenter-skin-osmc all 18.2.0-33 [9,268 kB]
Get:5 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main armhf vero3-mediacenter-osmc armhf 18.6.0-5 [93.0 MB]
Get:6 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main armhf vero3-device-osmc armhf 1.4.4 [6,538 B]
Get:7 http://ftp.fau.de/osmc/osmc/apt stretch-devel/main armhf armv7-eventlircd-osmc armhf 1.4.3 [36.9 kB]
Fetched 137 MB in 11s (11.7 MB/s)
Preconfiguring packages ...
Selecting previously unselected package vero3-bootloader-osmc.
(Reading database ... 24267 files and directories currently installed.)
Preparing to unpack .../0-vero3-bootloader-osmc_1.3.0-1_armhf.deb ...
Unpacking vero3-bootloader-osmc (1.3.0-1) ...
Selecting previously unselected package vero364-image-3.14.29-157-osmc:arm64.
Preparing to unpack .../1-vero364-image-3.14.29-157-osmc_157_arm64.deb ...
Examining /etc/kernel/preinst.d/
Done.
Unpacking vero364-image-3.14.29-157-osmc:arm64 (157) ...
Preparing to unpack .../2-vero364-kernel-osmc_3.9.157_arm64.deb ...
Unpacking vero364-kernel-osmc:arm64 (3.9.157) over (3.9.153) ...
Preparing to unpack .../3-mediacenter-skin-osmc_18.2.0-33_all.deb ...
Unpacking mediacenter-skin-osmc (18.2.0-33) over (18.2.0-30) ...
Preparing to unpack .../4-vero3-mediacenter-osmc_18.6.0-5_armhf.deb ...
Unpacking vero3-mediacenter-osmc (18.6.0-5) over (18.5.0-6) ...
Preparing to unpack .../5-vero3-device-osmc_1.4.4_armhf.deb ...
Unpacking vero3-device-osmc (1.4.4) over (1.4.2) ...
Preparing to unpack .../6-armv7-eventlircd-osmc_1.4.3_armhf.deb ...
Unpacking armv7-eventlircd-osmc (1.4.3) over (1.3.9) ...
Processing triggers for mime-support (3.60) ...
Setting up vero3-bootloader-osmc (1.3.0-1) ...
11+0 records in
11+0 records out
11 bytes copied, 0.00109998 s, 10.0 kB/s
1632+0 records in
1632+0 records out
835584 bytes (836 kB, 816 KiB) copied, 0.0579136 s, 14.4 MB/s
Setting up armv7-eventlircd-osmc (1.4.3) ...
Setting up vero364-image-3.14.29-157-osmc:arm64 (157) ...
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.14.29-157-osmc /boot/vmlinuz-3.14.29-157-osmc
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal-osmc 3.14.29-157-osmc /boot/vmlinuz-3.14.29-157-osmc
run-parts: executing /etc/kernel/postinst.d/inform-updater 3.14.29-157-osmc /boot/vmlinuz-3.14.29-157-osmc
run-parts: executing /etc/kernel/postinst.d/upload-to-emmc 3.14.29-157-osmc /boot/vmlinuz-3.14.29-157-osmc
7+1 records in
7+1 records out
8318976 bytes (8.3 MB, 7.9 MiB) copied, 0.20862 s, 39.9 MB/s
0+1 records in
0+1 records out
83968 bytes (84 kB, 82 KiB) copied, 0.0111973 s, 7.5 MB/s
Setting up mediacenter-skin-osmc (18.2.0-33) ...
Setting up vero364-kernel-osmc:arm64 (3.9.157) ...
Setting up vero3-mediacenter-osmc (18.6.0-5) ...
Setting up vero3-device-osmc (1.4.4) ...
osmc@osmc:~$ sudo reboot
Please upload full logs.
I’ll reproduce this here.
We’ve fixed the bookmarks issue, but the screenshot issue may be different.
thank you sir!
any luck?
This will take some time to look at, so it is lower priority.
Our focus is on the 4.9 kernel now.
ok
