I was using raspbmc for a while but I couldn’t anymore watch youtube. So I decided to switch to osmc although it is still a RC version. I installed osmc using a SD card on a rasp B. Installation went well but it is not usable with mouse (USB) only. Mouse wheel doesn’t seem to be active. There seems to be some (too fast) auto-scroll in other situations. So I can’t access most parts of menus.
Want can I do to use osmc with my rasp and usb mouse?
As far as I understand, one have to go to setting menu. Unfortunately, it is not visible on my screen (1920x1080). I imagine that I have to scroll down to find it… but I can’t scroll. Another method to use Confluence? (like ssh/command line)
I’m afraid I don’t know how to do it from the command line.
The alternative is to use a remote control, which is what the OSMC skin is designed for.
Derek
So, I connected with a browser on another computer just using IP adress, not the port part (:8080). I was able to switch to Confluence. Presently I’m doing some more fine tunning.
You’re talking about using a remote. Do you mind a dedicated one for the rasp or the one of the TV through DVI link? I have a Samsung TV (2 years old) and I would be very pleased to use the one the TV.
