My SD-card suddenly got filled? What has happend?
When I look in “df -h” it says that /dev/mmcblk0p2 is filled 100% however I am not able to locate, what is filling the disk?
Anyone with same problem?
Also tried “ncdu” inside “/dev”
Here it doesn’t say that “mmcblk0p2” fills anything…
Try ncdu from/ and work your way down.
Actually I even tried to do that.
There is nothing below here that seems mystic. Inside home is my home folder and my external harddisk folder.
The external harddisks shouldn’t cap any space on the SD-card.
So what now?
Problem solved… Movie was incorrectly placed. You can remove the topic, if you want. My bad.
