I have encounter problems with latest version OSMC on Rpi3. On fresh installation which goes normally, osmc starts to freze from time to time. I found that sd card write rate is very low (sometime aprox. 10kB/s) and after few seconds or minutes sdcard becomes read-only. I tried with another card and the result is the same. I tested both cards on PC and the write transfer was aprox. 10MB/s.
I found following errors in dmesg:
[13222.329700] mmc0: =========== REGISTER DUMP ===========
[13222.329705] mmc0: SDCMD 0x00000099
[13222.329710] mmc0: SDARG 0x0037c0f8
[13222.329715] mmc0: SDTOUT 0x017d7840
[13222.329720] mmc0: SDCDIV 0x00000003
[13222.329725] mmc0: SDRSP0 0x00000900
[13222.329730] mmc0: SDRSP1 0x00001918
[13222.329734] mmc0: SDRSP2 0xffffffff
[13222.329740] mmc0: SDRSP3 0x0002400f
[13222.329744] mmc0: SDHSTS 0x00000001
[13222.329749] mmc0: SDVDD 0x00000001
[13222.329754] mmc0: SDEDM 0x0001080a
[13222.329759] mmc0: SDHCFG 0x0000040e
[13222.329764] mmc0: SDHBCT 0x00000200
[13222.329768] mmc0: SDHBLC 0x00000010
[13222.329773] mmc0: ===========================================
[13222.329992] mmcblk0: error -110 transferring data, sector 3653880, nr 16, cmd response 0x900, card status 0xc00
[13232.567802] mmc0: timeout waiting for hardware interrupt.
[13232.567821] [53bea6cc] TSK< aa41bdbc 0
[13232.567831] [53bea6d9] TSK> aa41bdbc 0
[13232.567840] [d3c118d4] PRD< ad2e2a40 0
[13232.567847] [d3c118d5] PRD1 ada36d10 0
[13232.569690] [d45fc07a] FCM> ad2e2968 0
[13232.569697] [d45fc07a] CMD 19 200
[13232.569704] [d45fc07a] REQ> ad2e2968 0
[13232.569712] [d4f9981c] TIM< 0 0
[13232.569725] mmc0: sbc op 23 arg 0x10 flags 0x15 - resp 00000000 00000000 00000000 00000000, err 0
[13232.569737] mmc0: cmd op 25 arg 0x37c0f8 flags 0xb5 - resp 00000900 00000000 00000000 00000000, err 0
[13232.569744] mmc0: data blocks 10 blksz 200 - err 0
[13232.569754] mmc0: stop op 12 arg 0x0 flags 0x49d - resp 00000000 00000000 00000000 00000000, err 0
[13232.569759] mmc0: =========== REGISTER DUMP ===========
[13232.569763] mmc0: SDCMD 0x00000099
[13232.569769] mmc0: SDARG 0x0037c0f8
[13232.569774] mmc0: SDTOUT 0x017d7840
[13232.569779] mmc0: SDCDIV 0x00000003
[13232.569784] mmc0: SDRSP0 0x00000900
[13232.569789] mmc0: SDRSP1 0x00001918
[13232.569794] mmc0: SDRSP2 0x7fffffff
[13232.569799] mmc0: SDRSP3 0x0002482e
[13232.569803] mmc0: SDHSTS 0x00000001
[13232.569808] mmc0: SDVDD 0x00000001
[13232.569814] mmc0: SDEDM 0x0001080a
[13232.569818] mmc0: SDHCFG 0x0000040e
[13232.569823] mmc0: SDHBCT 0x00000200
[13232.569828] mmc0: SDHBLC 0x00000010
[13232.569832] mmc0: ===========================================
[13232.570065] mmcblk0: error -110 transferring data, sector 3653880, nr 16, cmd response 0x900, card status 0xc00
[13232.570582] blk_update_request: I/O error, dev mmcblk0, sector 3653880
[13232.570599] blk_update_request: I/O error, dev mmcblk0, sector 3653888
[13232.570916] Aborting journal on device mmcblk0p2-8.
[13806.022517] EXT4-fs error (device mmcblk0p2): ext4_journal_check_start:56: Detected aborted journal
[13806.022547] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
Could it be software (sd card driver) problem or hardware? What should I check next?
