I use a V4k+ and a Mythtv backend to play live and recorded video on my Hisense TV. HD is fine, SD does not display correctly. The picture is compressed horizontally with black bars at either end.
I also have a V4k connected a Sony TV and it uses the same system. It displays correctly, so the problem appears to be the Hisense TV.
if I blank the 720 x 576 resolution using the white-list setting, the system up-scales to the next resolution, 1280 x 720. This fills the screen, but looks terrible and the playback is not smooth.
I’ve read the white-list how-to and played around with the settings, but to no avail. My V4k+ is basically set up as per that document.
It’s not a huge problem as most stuff worth watching these days is HD and that works well.
Any suggestions regarding how to fix this would be appreciated.
