Hi there
thought I would let you know of a possible bug. When using the OSMC settings to set the sdtv mode, when you set it to PAL, it will then create the wrong value in the config.txt file. It created : SDTVmode=3 (Brazilian PAL), and not SDTVmode=2 (Normal PAL)
Once I manually changed it to mode=2 it worked fine
Love your work
Glen
