Search fuction on OSMC
Hi there,
since a few days I have a Rii keyboard, which I usually use for my raspberry with osmc on it.
Is there any search engine which I can install?
Because if I want to see a movie from my library and its f.e. at H, I want to press H on the keyboard and want to be automatically at the beginning of the movies which starts at H.
Is this possible?
Thank you in advance!
Phil
When in a list, press Shift and the letter you want to jump to.
If you want a proper search engine you have the Global Search addon which you can install from the main Kodi repository (under Program addons).
This was super helpful. Thank you.
