I am new to OSMC.
I’m in my movie list, browsing files and I would like to search rather than scroll.
If I get the options to open (key up or key left, depending on the view), there is a search option.
As I use the search option, it cannot find anything, no matter what I type.
So, what’s the right way to search for movies?
Thanks.
Are you browsing just the files or have you scanned your content into the library?
I think the search function only searches the kodi library, not file names.
You’re right. I was browsing the files, not the library. Library search works whereas file search doesn’t.
the_bo
4
Another useful tip is to hold down shift then press letter this will jump to first movie beginning with that letter in list.
