Hello,
On one of my TV show (McGyver) I can’t seek or it freezes the video, still I can stop it.
Can anyoen tell me if there is a fix / debug to make ? ![]()
Hello,
It would help to see some logs and know what device you are playing the file on.
Hi Sam, Yes I’m using Vero 4K+. I’ll make a log hence.
Here it is sir !
There are a lot of discontinuities. It could be a bad rip.
I’d try play from local storage (not NFS) to rule out that being the cause as well.
Thank you Sam, I’ll check another rip hence.
Thanks a lot
