I just updated both of my vero 4k+ with osmc September update.
h.264 TV shows are kind of playing with stuttering video when hardware acceleration is enabled. It is independent of network connectivity (Wifi / LAN) and it worked before update. Disabling HW acceleration in settings → player → video seems to help with resolution up to 1080p. I did not try any further videos.
I can provide sample file, if needed.
One of the four cpu cores is at 100% Load and temperature is also about 70°C on system-infomation … <= fixed by disabling raspotify
Stephan
It would be good to see some logs
Hi, Sam.
Thanx für your answer.
I could send you a link with a short video (300 MB) or shall I enable logging reboot play and upload?
Disabling spotty does not help.
Without debug:
2022-09-19 19:01:43.732 T:2978 INFO : CActiveAESink::OpenSink - initialize sink
2022-09-19 19:01:43.733 T:2978 INFO : CAESinkALSA::Initialize - Requested layout: FL, FR
2022-09-19 19:01:43.733 T:2978 INFO : CAESinkALSA::Initialize - set digital_codec 0
2022-09-19 19:01:43.733 T:2978 INFO : CAESinkALSA::Initialize - Attempting to open device “default”
2022-09-19 19:01:43.738 T:2978 INFO : CAESinkALSA::Initialize - Opened device “default”
2022-09-19 19:01:43.739 T:2978 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-09-19 19:01:43.739 T:2978 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-09-19 19:01:43.744 T:2978 INFO : CAESinkALSA::Initialize - speaker layout 0
2022-09-19 19:01:46.512 T:2961 INFO : VideoPlayer::OpenFile: nfs://192.168.55.1/video/media1/test/9-1-1 Lone Star - S03E18 - Ein freundlicher und wolkenloser Morgen-00.00.00.000-00.05.17.374.mkv
2022-09-19 19:01:46.513 T:7620 INFO : Creating InputStream
2022-09-19 19:01:46.569 T:7620 INFO : Creating Demuxer
2022-09-19 19:01:46.610 T:7620 INFO : Opening stream: 0 source: 256
2022-09-19 19:01:46.610 T:7620 INFO : CVideoPlayerVideo::OpenStream - Creating codec: 27
2022-09-19 19:01:46.610 T:7620 INFO : CDVDVideoCodecAmlogic: using Amlogic decoder H.264/MVC
2022-09-19 19:01:46.612 T:7620 INFO : DVDVideoCodecAmlogic: Opened Amlogic Codec
2022-09-19 19:01:46.612 T:7620 INFO : Creating video thread
2022-09-19 19:01:46.613 T:7623 INFO : running thread: video_thread
2022-09-19 19:01:46.613 T:7620 INFO : [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 25.000, 3D: false
2022-09-19 19:01:46.616 T:7620 INFO : Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (27) (weight: 0.000)
2022-09-19 19:01:46.625 T:2961 INFO : VideoPlayer: OnLostDisplay received
2022-09-19 19:01:46.625 T:2961 WARNING : CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2022-09-19 19:01:46.844 T:2961 INFO : GLES: Maximum texture width: 4096
2022-09-19 19:01:46.847 T:7620 INFO : Opening stream: 1 source: 256
2022-09-19 19:01:46.847 T:7620 INFO : Finding audio codec for: 86019
2022-09-19 19:01:46.847 T:7620 INFO : Creating audio thread
2022-09-19 19:01:46.847 T:7625 INFO : running thread: CVideoPlayerAudio::Process()
2022-09-19 19:01:46.933 T:2961 INFO : VideoPlayer: OnResetDisplay received
2022-09-19 19:01:46.948 T:7623 INFO : CBitstreamConverter::Open bitstream to annexb init
2022-09-19 19:01:46.954 T:7625 INFO : CAEStreamParser::TrySyncAC3 - AC3 stream detected (6 channels, 48000Hz)
2022-09-19 19:01:46.954 T:7625 INFO : CVideoPlayerAudio: display reset occurred, checking for passthrough
2022-09-19 19:01:46.955 T:7625 INFO : Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, pass-through)
2022-09-19 19:01:46.956 T:2978 INFO : CActiveAESink::OpenSink - initialize sink
2022-09-19 19:01:46.956 T:2978 INFO : CAESinkALSA::Initialize - Requested layout: RAW, RAW
2022-09-19 19:01:46.956 T:2978 INFO : CAESinkALSA::Initialize - set digital_codec 2
2022-09-19 19:01:46.957 T:2978 INFO : CAESinkALSA::Initialize - Attempting to open device “hdmi:CARD=AMLMESONAUDIO,DEV=0”
2022-09-19 19:01:46.963 T:2978 INFO : CAESinkALSA::Initialize - Opened device “hdmi:CARD=AMLMESONAUDIO,DEV=0,AES0=0x06,AES1=0x82,AES2=0x00,AES3=0x02”
2022-09-19 19:01:46.966 T:2978 INFO : CAESinkALSA::Initialize - speaker layout 0
2022-09-19 19:01:47.072 T:2961 INFO : Constructing CRendererAML
2022-09-19 19:01:47.113 T:2961 INFO : [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 25.000, 3D: false
2022-09-19 19:01:47.116 T:2961 INFO : Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (27) (weight: 0.000)
2022-09-19 19:01:54.099 T:2961 INFO : CVideoPlayer::CloseFile()
2022-09-19 19:01:54.100 T:2961 INFO : VideoPlayer: waiting for threads to exit
2022-09-19 19:01:54.215 T:2961 INFO : VideoPlayer: finished waiting
2022-09-19 19:01:54.332 T:2978 INFO : CAESinkALSA::Initialize - Requested layout: FL, FR
2022-09-19 19:01:54.332 T:2978 INFO : CAESinkALSA::Initialize - set digital_codec 0
2022-09-19 19:01:54.333 T:2978 INFO : CAESinkALSA::Initialize - Attempting to open device “default”
2022-09-19 19:01:54.338 T:2978 INFO : CAESinkALSA::Initialize - Opened device “default”
2022-09-19 19:01:54.339 T:2978 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-09-19 19:01:54.339 T:2978 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-09-19 19:01:54.340 T:2978 INFO : CAESinkALSA::Initialize - speaker layout 0
2022-09-19 19:01:54.534 T:2961 INFO : GLES: Maximum texture width: 4096
Video / Audio Codec with Mediainfo:
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Duration : 5 min 17 s
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
I need to see full logs with debugging. As explained below:
reproduce the issue
Thanks for your patience.
I assume the issue occurs when playing 9-1-1 Lone Star - S03E18 - Ein freundlicher und wolkenloser Morgen-00.00.00.000-00.05.17.374.mkv.
Did you test by playing from local storage?
I see you have NFS with path substitution.
Does it occur with all H264 files?
Would you be able to share a problematic sample?
It does occur with all episodes of this tv show when using hardware acceleration.
Before update I could watch the episodes of the show.
I watched a different tv show without problems.
I will send you a pm with a link. Please confirm when you got the sample.
It would be good if you could provide the sample here
