how do i get the serial number from PI 2 if i already installed OSMC?
Should be able to find it in system info under Settings.
ok that didnt work
If you mean the Pi’s serial number you will find it in MyOSMC under Pi Config.
Greetings. I am in the same boat as the chap who started this thread. I have looked all around the “Pi Config” area for a number and am at a loss. I am grateful for continued assistance.
Hi guys. Just found…flip your skin from OSMC to Confluence…Then look Settings : System Info : Hardware – you will find it right here.
As an alternative you can do it from the command line.
cat /proc/cpuinfo
