Setting missing after upgrade osmc
just updated to latest osmc and after kodi original skin no setting missing from screen help
Your question is unclear:
  • by ‘kodi original skin’ do you mean confluence?
  • or are you talking about the OSMC skin, which is the default on OSMC installation?
If it is Confluence, then you just use ‘System’ on the home screen
Derek
onfluence… Yes, thank you Derek, there is setting missing, instead on setting now is osmc setting. So how one can get in to option of skin loading… Sound setting, subtitle setting? Kind regards
Jay
Hi Derek, thank you so much. Really appreciate your help. Yes before it was under system heading. And now it’s in system it self… Sorted now
Kind regards
Jay
Choosing System directly has always worked. All that happened is we re-purposed the redundant settings option, which used to take you to the exact same place as the main System menu.
