Need help setting up autofs. I followed the tutorial and when I check to see if it’s set up correctly in terminal I get error message:
osmc@osmc:~$ ls -lah /mnt/kuro/gtest
ls: cannot open directory ‘/mnt/kuro/gtest’: No such file or directory
error log from automount:
Starting automounter version 5.1.2, master map /etc/auto.master
using kernel protocol version 5.02
lookup_nss_read_master: reading master file /etc/auto.master
do_init: parse(sun): init gathered global options: (null)
lookup_read_master: lookup(file): read entry +dir:/etc/auto.master.d
lookup_nss_read_master: reading master dir /etc/auto.master.d
lookup(dir): dir map /etc/auto.master.d missing or not readable
lookup(file): failed to read included master map dir:/etc/auto.master.d
lookup_read_master: lookup(file): read entry +auto.master
lookup_nss_read_master: reading master files auto.master
lookup(file): failed to read included master map auto.master
lookup_read_master: lookup(file): read entry /-
master_do_mount: mounting /-
automount_path_to_fifo: fifo name /var/run/autofs.fifo–
lookup_nss_read_map: reading map file /etc/auto.smb.shares
mounted direct on /mnt/kuro/gtest with timeout 15, freq 4 seconds
do_mount_autofs_direct: mounted trigger /mnt/kuro/gtest
st_ready: st_ready(): state = 0 path /-
handle_packet: type = 5
handle_packet_missing_direct: token 4, name /mnt/kuro/gtest, request pid 2962
attempting to mount entry /mnt/kuro/gtest
lookup_mount: lookup(file): looking up /mnt/kuro/gtest
lookup_mount: lookup(file): /mnt/kuro/gtest → -fstype=cifs,rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc ://192.168.1.4/gtest/
parse_mount: parse(sun): expanded entry: -fstype=cifs,rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc ://192.168.1.4/gtest/
parse_mount: parse(sun): gathered options: fstype=cifs,rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc
parse_mount: parse(sun): dequote(“://192.168.1.4/gtest/”) → ://192.168.1.4/gtest/
parse_mount: parse(sun): core of entry: options=fstype=cifs,rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc, loc=://192.168.1.4/gtest/
sun_mount: parse(sun): mounting root /mnt/kuro/gtest, mountpoint /mnt/kuro/gtest, what //192.168.1.4/gtest/, fstype cifs, options rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc
do_mount: //192.168.1.4/gtest/ /mnt/kuro/gtest type cifs options rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc using module generic
mount_mount: mount(generic): calling mkdir_path /mnt/kuro/gtest
mount_mount: mount(generic): calling mount -t cifs -o rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.4/gtest/ /mnt/kuro/gtestmount error(22): Invalid argument
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
mount(generic): failed to mount //192.168.1.4/gtest/ (type cifs) on /mnt/kuro/gtest
dev_ioctl_send_fail: token = 4
failed to mount /mnt/kuro/gtest
st_expire: state 1 path /-
expire_proc: exp_proc = 4103074896 path /-
expire_cleanup: got thid 4103074896 path /- stat 0
expire_cleanup: sigchld: exp 4103074896 finished, switching from 2 to 1
st_ready: st_ready(): state = 2 path /-
statemachine:1500: got unexpected signal 28!
Text in /etc/auto.smb.shares
/mnt/kuro/gtest -fstype=cifs,rw,ver=3.0,credentials=/home/osmc/.smbcredentials,iocharset=utf8,uid=osmc,gid=osmc ://192.168.1.4/gtest/
I’ve tried every “ver=” and without it. Tried without smbcredentials and having user and pw in command line.
.smbcredentials is set up properly as far as I can tell.
username=myusername
password=mypassword
Added to end of /etc/auto.master
/- /etc/auto.smb.shares --timeout 15 browse
I am able to see the directory if I add the directory through SMB so the server is fine.
Also able to see the directory when I browse to root, but kodi cannot find any files in the directory.
Tutorials I followed:
Thanks for any help.
