Hi! I am using an USB sound card and was setting different volume values for each channel with alsamixer. It seems the July update broke something. Whatever I set in alsamixer kodi just seems to ignore it. Just tried on a fresh install and this behavior is still present in the august update as well.
I am pretty sure this worked before. Is there something wrong with how I installed alsa-utils? I just used sudo apt-get install alsa-utils, then run alsamixer, edit the settings and exit.
