Good Morning;
I have two raspberry Pi 1 connected to the same router. One has osmc, the other one runs as server running raspbian.
Osmc connects via sftp to the server to access the collection of movies, music …
The problem is that if at some point the internet access fails, osmc does not connect to the server which, I repeat, is connected to the same router. It’s not a problem with IPs. Osmc ip: 192.168.1.9 Server IP: 192.168.1.99
If internet access fails, osmc ping the server without problem, but if I try to play any content, it says that the content is not available and asks if I want to remove it from the collection.
The Kodi log says:
ERROR: SFTPSession: Password present, but does not support password authentication
ERROR: SFTPSession: No authentication method successful
But only until the internet access returns, at that time you can connect and play content without problem …
When there is no internet, I can access via sftp from other computers to the server without problem. I mean, the bug is safe in osmc.
Ideas?
a greeting
