I say from Mac because I have nothing else.
Odd thing is that I can SSH into it correctly but it doesn’t seem like I can SFTP to the raspberry using Filezilla. It just times out.
If I use incorrect settings it fails, or another protocol too. If all is seemingly correct it goes:
| Response: | fzSftp started, protocol_version=8 |
| Command: | open “osmc@192.168.1.34” 22 |
| Command: | Pass: **** |
| Error: | Connection timed out after 20 seconds of inactivity |
| Error: | Could not connect to server |
Any ideas on where to look at?
