Shadertoy not present and working after latest update.
It is not presenty in either scrensavers or misic addon.
Was present and working before update
I am Raspberry PI3B+
Some logs would be useful so we can see what version of OSMC you are running
I did an update on Sunday by MYOSMC. That is whenShadertoys errored after the update.Cannot uninstall it by GUI. Don’t know how to by SSH
osmc@LISA-ROBERTS-RADIO:~$ sudo journalctl
– Journal begins at Sun 2024-06-02 21:04:27 BST, ends at Mon 2024-06-03 09:20:>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Booting Linux on physical CPU 0x0
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Linux version 5.15.92-1-osmc (root@j>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: CPU: ARMv7 Processor [410fd034] revi>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: CPU: div instructions available: pat>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: CPU: PIPT / VIPT nonaliasing data ca>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: OF: fdt: Machine model: Raspberry Pi>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Memory policy: Data cache writealloc
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Reserved memory: created CMA memory >
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: OF: reserved mem: initialized node l>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Zone ranges:
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: DMA [mem 0x0000000000000000-0>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Normal empty
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Movable zone start for each node
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Early memory node ranges
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: node 0: [mem 0x0000000000000000->
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Initmem setup node 0 [mem 0x00000000>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: percpu: Embedded 16 pages/cpu s35980>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: pcpu-alloc: s35980 r8192 d21364 u655>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Built 1 zonelists, mobility grouping>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Kernel command line: coherent_pool=1>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Unknown kernel command line paramete>
lines 1-23
– Journal begins at Sun 2024-06-02 21:04:27 BST, ends at Mon 2024-06-03 09:20:55 BST. –
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Linux version 5.15.92-1-osmc (root@jenkins) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 >
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: CPU: div instructions available: patching division code
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Reserved memory: created CMA memory pool at 0x1ec00000, size 256 MiB
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: DMA [mem 0x0000000000000000-0x000000003b3fffff]
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: node 0: [mem 0x0000000000000000-0x000000003b3fffff]
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: percpu: Embedded 16 pages/cpu s35980 r8192 d21364 u65536
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: pcpu-alloc: s35980 r8192 d21364 u65536 alloc=16*4096
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Built 1 zonelists, mobility grouping on. Total pages: 240555
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 vc_mem.mem_bas>
Jun 02 21:04:27 LISA-ROBERTS-RADIO kernel: Unknown kernel command line parameters “osmcdev=rbp2”, will be passed to user space.
Please upload proper logs via My OSMC.
How do I get to logs? By ssh?
Other visualizations work
reproduce the issue
upload the log set (all configs and logs!) either using the
Sorry, I made several mistakes in not reading and uploading the log here.
I have also enclosed a pic of the error on the screen
It is dim, not full screen and not animated
https://paste.osmc.tv/juritatemu
https://paste.osmc.tv/lipizuxudi
