Does anyone have a repo or compiled source containing the Shadertoy visualizations and screensavers for the current version of OSMC on Kodi 19?
I believe it’s already included now – but whether it works as expected is another question…
You’re my man
Yes, they are in the Kodi repo and just need to be activated, in order to choose them in the screensaver and player menu.
Maybe a short feedback: Screensavers seem to work perfectly flawless. The player animations kind of work. In another version couple years back, one could set the player animations to random so that every time one switched the animation back on, a different shader would come up. Unfortunately this has been discontinued obviously. On the positive side is that meanwhile you can add your own shaders - wow.
Some of the shipped shaders seem not to work in the player animation. The screensaver ones do just fine though
you can found a solution for this issue by compiling Shadertoy visualization yourself. Same issue with Matrix visualization : Visualizations not working in 19.3? - #26 by JonnyG
