Whenever I try out the screensavers after the october update I get the following message:
Add-on couldn’t be loaded.
An unknown error has occured.
Screensavers had been removed as they were the reason for the crashes of the October Update. Might come back in the next update.
Ok then, I was under the impression that it was only deactivated on the raspberry.
I will then be diligently waiting until it will be released again.
Maybe you are right, let @sam_nazarko comment
That’s right - it was only removed for Pi.
