I’m trying to get shairport-sync working on my OSMC install (RPi 3).
Per this issue on GitHub, I’m struggling to get audio out from the analogue jack. AirPlay works fine, but audio comes through HDMI only and and I want it through analogue only.
Has anyone setup shairport-sync successfully on OSMC with analogue audio output?
Any tips on how to get this configured would be much appreciated.
There’s a setting under the kodi settings for audio - have you found that?
Are you using the correct cable for the RPi3 analog port - there have been cases where this 4-pole connector has been incorrectly used
Derek
