If you’ve read my posts you will not be surprised that I plugged in the switch, connected the ethernet cables, and that’s it. I can see it in the Unifi Controller which runs on PC, but haven’t ever configured anything on it except to update the firmware when prompted. Whatever defaults it has, that’s what its doing.
Experientially, through the Unifi switches …I have 3 of them; whole house is wired with ethernet to every room… I can move files to & from any device, and I can play my content (stored on the QNAP NAS) on all Vero4Ks (and prior to that, briefly, a Tronfy MX4 box, and prior to that, WDTV boxes). I’m not dumb, though like all of us, sometimes in hindsight my actions weren’t wise. But I just don’t invest time in digging into the details of something when there’s not a need or benefit.
I believe you are referring to my comment that I had trouble setting up a local folder for config backups. When you try to do that via the GUI, and start browsing for a place, it shows you a LOT of folders. Maybe all of them. Not knowing which have write-permissions set to ‘allow’, and which do not, one must look for a place by trial & error. After a few failures, I gave up. There is no default folder already set up and filled in or suggested. There’s no hint offered, that I noticed, that one should browse down to the OSMC folder. There is no visual indication that certain folders are write-protected. And yes I do realize some of these ideas are non-trivial to implement.
I have since created a ‘backup’ folder under \osmc, and have the config for each device backed up there. I can now also see that folder from Windows File Explorer.
More generally… probably most of the users on this forum, and users of these devices, are well-versed at linux coding. I’m not. I could invest time in learning yet another coding and command language, but have not. I used to know some stuff but didn’t keep using it so it’s faded. CHOWN sounds like you missed spelled eating a hearty lunch.
The Vero4K box is awesome. But many things on it are difficult to figure out and hard to implement. The user base could grow a LOT and the business owners could make more profits, by making it more newb friendly in a zillion little ways. More users means a healthier ecosystem in the long term.
Things like GUI wizards, on-screen hints, guides with screenshots, links from the device GUI straight to those guides, and being able to do things with no command-line stuff, would all be very helpful.
The people on this community are a (free) resource that could be organized to collect newb perspectives & suggestions, prioritize them, write the guides, raise the more important issues up to the devs for consideration as new features, etc. I have browsed some of the guides and used a couple of them. They are written as if the reader already knows linux, kodi, etc in detail.
I have participated in things like this for other interests. A long time ago I was a beta user of a homebrew system for WDTV boxes (run by @Markster). Above, @bmillham asked for some input and when the dust settles on this project I will provide it.
