Hi all
Can someone tell me how to create a short cut for an add on ive installed? Like the Security Camera one?
Thanks!
Hi all
Thanks!
I believe this depends on the skin you’re using. Can you let us know which skin you’re using?
HI Sam
Its just the default, whatever ships with the unit.
Hi Sam, any suggestions? Thank you
What kind of shortcut do you want?
Do you want it right on your home screen?
You can add add-ons to favorites (kind of like a shortcut) and from there you can easily link them in various places.
If you want to add an add-on to your home screen you can do that in skin settings.
