Subject sez it all. Have log level set to “0” in advancedsettings.xml
No – we need as much information as possible. That’s the whole point of the logs.
What exactly is the issue that your trying to capture in the logs? Typically one would reboot a couple times, enable debug, do whatever to reproduce their issue, and then upload. Using an advancedsetting.xml file to enable logs is typically only done when you need to log an intermittent and don’t want the overlay showing.
Changed it back to “1”.
A video playback problem I’ve seen posted by others here . When it reoccurs I will create new thread with log.
