I have been using the Vero 4k since 2018. Overall has been a good experience except for the last year with the cec bug.
With the Vero V now out I am wondering if I need to upgrade. Apart from the latest hardware it seems for my use case which is just watching 4k movies the current vero 4k should be fine.
I hope that there will be some video post processing improvements planned as well? I remember seeing a noticable video improvement when using MadVR on my PC.
Iâm hoping that the new CPU has the capabilities to do at least some basic video improvements?
Thanks everyone all very helpful. All I use my Vero for is 4k movies on a oled tv. So I think I will just wait for it to break before getting a new one.
If by âa bitâ you mean significantly, then sure. The Vero 4K in the UI seems sluggish in comparison. It even feels faster navigating the UI than my RPi 4âs that are all running from the same MySQL database (as a subjective comparison).
** An internal remote dongle so you have two free USB ports.*
Not sure this one is a plus to be fair, the new remote is much less âpositiveâ than the previous one. You need to be closer to the box or you can get freezes of the remote.
But the UI is quicker and doesnât seem to get stuck scrolling through large libraries.
