Trying to display hidden files saved on USB stick using remote. I cannot find ‘appearance>show hidden files’ command. In fact I cannot find the ‘Appearance’
Using Vero 4K with current (March 2019) updates.
The setting (Show hidden files and directories) you are looking for is now in “Settings->Media Settings->General”.
Note that your settings level has to be at least “Advanced” to see this setting.
Many thanks. I have it now.
And what is the correct way to unmount the USB drive when I wish to remove it?
Use the context menu key in the file manager then remove safely. If it doesn’t disappear then it is still in use by something.
