Hi Friends, I type from Brazil.
Is possible show ip wired ou wireless in home Screen, after boot ??
or add-on ?
thank you,
or add-on ?
thank you,
You can see the network info via MyOSMC, you should be able to see shortcut for this on the home screen; if you are using the OSMC skin.
Thanks Tom.
It’s also always been available in system info under settings menu.
Okay, but example,
user not mouse or keyboard
Thanyou
CEC remote?
If you have no way to navigate OSMC that is quite a specific case that should not need to be catered for by disturbing the clean look of the Home screen for anyone else
