Hi I installed the latest OSMC on RPi3.
When select Estuary Skin it’s working fine but after power off or restart, it’s going back to the OSMC default skin. Is there any way to avoid it?
reproduce the issue
upload the log set (all configs and logs!) either using the
Try changing the skin and then going to Power → Exit.
Kodi will re-open after a few seconds and this may solve your issue.
This worked. Thanks Sam!
