Hello
Where can I find the files which defined my customized menus so that I can migrate them into a new computer without having to recreate everything from scratch?
Thx
By what method did you customize them? If only by menu options, then /home/osmc/.kodi/userdata/guisettings.xml should be your huckleberry.
