Each time i launch the osmc or doing something in the menu, i’m getting a “skin shortcut error”.
this is what i can see in the kodi.log:
23:32:05 119819.570312 T:1734804464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.ValueError'> Error Contents: bad marshal data (string ref out of range) Traceback (most recent call last): File "/home/osmc/.kodi/addons/script.skinshortcuts/default.py", line 37, in <module> import xmlfunctions, datafunctions, library, nodefunctions ValueError: bad marshal data (string ref out of range) -->End of Python script error report<-- 23:32:07 119822.031250 T:1770902512 WARNING: CSkinInfo: failed to load skin settings
I run commands from another post that Sam suggested (http://dsh.re/8bde4), but it didn’t help.
Aug 08 20:06:43 osmc mediacenter[345]: Starting Kodi...
Aug 08 20:06:43 osmc sudo[442]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
Aug 08 20:06:43 osmc sudo[442]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Aug 08 20:06:44 osmc sudo[442]: pam_unix(sudo:session): session closed for user osmc
Aug 08 20:06:44 osmc mediacenter[345]: Kodi exited with return code 139 after 0 hours, 0 minutes and 1 seconds
