I’m using default OSMC skin. Would be really useful if an OSD indicator appeared when using the new “skip step” feature. eg: +10sec / +30sec / +60sec …
I’m finding it hard to keep track of how many seconds the video will skip forward or backwards.
So I used to be able to skip 30 seconds by pressing right, but after the recent update it is set to 10 seconds now. Is there a way to put it back? Or is there a new key for 30 seconds?
Double press… Or look into reverting to previous behavior here http://kodi.wiki/view/Skip_steps#Instant_skipping
Yeah, I figured it out probably 10 minutes later. It’s amazing how easy it is to be behind in the times these days (thanks!)
