There’s a strange slideshow effect that happens when playing back 1080p and 4K HEVC content. Audio still plays back normally. BT.709 and BT.2020 are both affected.
Here’s a link of the video capture: 37.83 MB file on MEGA
Also, here is a link to a source clip: 72.5 MB file on MEGA
Log: https://paste.osmc.tv/jasolaxopo
Thanks for taking a look at it!
General
Unique ID : 153619136597594551509054798579902685124 (0x7391F8327D897E26668D1AB3377F9FC4)
Complete name : /Volumes/TV Shows/Burn Notice/Season 02/Burn Notice - S02E01 - Breaking and Entering.mkv
Format : Matroska
Format version : Version 4
File size : 2.86 GiB
Duration : 43 min 10 s
Overall bit rate : 9 487 kb/s
Encoded date : UTC 2018-07-10 03:52:02
Writing application : mkvmerge v24.0.0 (‘Beyond The Pale’) 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9Video
Format : HEVC
Format profile : Main@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 8 844 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.178
Stream size : 2.67 GiB (93%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 198 MiB (7%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : NoText
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 42 min 21 s
Bit rate : 103 b/s
Count of elements : 729
Stream size : 32.1 KiB (0%)
Language : English
Default : No
Forced : No
