Slow download speed on vero 4K
hi all,
I’m experiencing really slow download speed on my vero 4K, 20/5MBit/s basically (with speedtest-cli).
Is there any way to debug/fix this? It was not the case previously, but I just started to see that things are buffering much more and i think this is the issue.
thx!
Some logs would help.
Also see: [How To] Check Network Performance with iperf3
What’s the actual speed of your connection?
thanks Sam,
this is the output when i test it:
[ 4] local 192.168.2.53 port 60283 connected to 192.168.2.84 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 11.3 MBytes 95.0 Mbits/sec
[ 4] 1.00-2.00 sec 11.2 MBytes 94.2 Mbits/sec
[ 4] 2.00-3.00 sec 11.2 MBytes 94.1 Mbits/sec
[ 4] 3.00-4.00 sec 10.5 MBytes 88.5 Mbits/sec
[ 4] 4.00-5.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 4] 5.00-6.00 sec 11.2 MBytes 93.8 Mbits/sec
[ 4] 6.00-7.00 sec 11.2 MBytes 93.8 Mbits/sec
[ 4] 7.00-8.00 sec 11.2 MBytes 94.0 Mbits/sec
[ 4] 8.00-9.00 sec 11.2 MBytes 94.1 Mbits/sec
[ 4] 9.00-10.00 sec 11.2 MBytes 94.1 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 112 MBytes 93.8 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 112 MBytes 93.6 Mbits/sec receiver
I have an 500/250Mbit internet line that is working fine on other devices but the OSMC.
From what source? As Sam advised, logs would be more helpful than anything.
any guess why a raspberry pi from the same network can do almost 100/100Mbit/s with speedtest-cli and osmc can do only 20/5? Even when i’m not streaming anything this is the speed I get with the command line tool.
No. We’ll need to see logs to give any useful debug advise.
If this is a Vero 4K and not a + model, then the iperf speeds are as expected and this isn’t a hardware or software issue. There will likely be a problem with the source of playback.
Did you check Speedtest was using the same mirror for both tests on each device?
