Having a bit of an issue with the vero. I installed some cat6 the other day from the media center area to my router to get away from the troublesome wifi extender.
When testing from my pc (in office - ethernet direct to router) through the new cat6 line direct to the vero, I was only only getting 140Mb. WTF is this I cried? And took the vero to the office directly to the router. 940Mb.
OK, back down to the media area. 940Mb. Ok great maybe a patch cable wasn’t quite pushed in properly.
So again this morning I check to find 140Mb/sec. WTF again? I do 1 thing only, and that is to remotely reboot the Vero, without even touching it. speed check back to 940Mb.
So it seems as if the vero eth is slowing down or dropping out and requiring the occasional reboot?
A log requires a restart, according to the instructions. A restart solves the problem, until the next time it slows down, which may be hours or days, I haven’t been able to reliably reproduce it yet. How would you suggest I log this behavior? Can I somehow produce logs without a reboot?
Jun 29 23:31:27 osmc nmbd[646]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.24 for name WORKGROUP<1d>.
Jun 29 23:31:27 osmc nmbd[646]: This response was from IP 192.168.1.1, reporting an IP address of 192.168.1.1.
Jun 29 23:32:44 osmc sshd[4293]: pam_unix(sshd:session): session closed for user osmc
alot of this before shutdown seems there are some conflicts in your network that needs your attention.
@Toast - can you elaborate? the vero is .24 and the gateway is .1 Not many devices on the system which is why I start all fixed IP’s at 20 and dhcp takes place from .3 upwards.
And why does the log refer to “subnet” .24? that’s weird. The vero’s ip is .24
Is this snippet repeated many times? what would the error indicate?
OK, I managed to get this ethernet slowdown to happen within a day. Again, on a GB network, restart the vero, perform iperf3, perfect 938MB tests.
Wait a few hours, repeat ad nauseum until eventually the vero ethernet speed drops to something around 100-200MB.
The ONLY thing that fixes this is a vero reboot. All other devices have been rebooted during all these experiments, cables swapped etc, routers, switches.
2020-02-26 12:50:47.953 T:3695096544 DEBUG: CAddonSettings[plugin.program.iptv.merge]: loading setting definitions
2020-02-26 12:50:47.953 T:3695096544 DEBUG: CAddonSettings[plugin.program.iptv.merge]: trying to load setting definitions from old format...
2020-02-26 12:50:47.955 T:3695096544 DEBUG: CAddonSettings[plugin.program.iptv.merge]: loading setting values
Those 3 lines appear over 10,000 times in your log. I’d suggest testing with that addon disabled.
Also, this happens quite a bit, about 45 minutes:
Feb 26 12:55:35 osmc nmbd[782]: [2020/02/26 12:55:35.572612, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
Feb 26 12:55:35 osmc nmbd[782]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.24 for name WORKGROUP<1d>.
Feb 26 12:55:35 osmc nmbd[782]: This response was from IP 192.168.1.1, reporting an IP address of 192.168.1.1.
And this is odd:
Feb 26 13:00:35 osmc nmbd[782]: This response was from IP 192.168.1.1, reporting an IP address of 192.168.1.1.
Feb 26 13:01:30 osmc ntpd[1011]: 193.27.208.100 local addr 192.168.1.24 -> <null>
Feb 26 13:03:23 osmc ntpd[1011]: 90.187.7.5 local addr 192.168.1.24 -> <null>
Feb 26 13:05:32 osmc ntpd[1011]: 37.235.209.151 local addr 192.168.1.24 -> <null>
Hey guys,
I just saw this thread and thought about posting my experience as well.
Basically the same what happens to floatingkiwi’s Vero, does happen to my Vero.
It seems like whenever the device is idling for a while the connection degrades to a 100 Mbit/s connection. (The user interface of my router displays "LAN 1 with 100 Mbit/s)
When it happens the next time, I’ll try what @sam_nazarko suggested.
